What do you do with an M332?
BSH
Baraboo, WI
I see these ammo trailers come up for auction now & then. I would never want one, they're so heavy. But I wonder, what would a person do in the civiian world with one of these trailers?
maddawg308
762
Appomattox, VA
It's not heavy. The M105 trailer is 2440 pounds empty. The M332 ammo trailer is 2800 pounds empty - not that much more. It tows like pulling a jeep behind you, you don't even know it's back there.
The up side to the M332 trailer, is that it is low to the ground. If you have a lot of heavy items you need to haul, like ammo (well, it is an ammo trailer), it is a lot easier to load it than load a M105 which is several feet off the ground. The loading ramp can be used to drive a lawn tractor or an ATV onto easily. The low center of gravity helps with towing a heavy load over rough ground. And, if you have a lot of rough, heavy object like bricks or firewood, the armored sides can take the beating and not dent up like the M105 body will.
I like the M332 better than the M105, just seems to me to be a more useful design for working around the farm.
dm22630
42
Front Royal, VA 22630
You can drive a 4wheeler right into one.
OR...
You can paint it John Deere Green & tow it behind your tractor! ;)
citizensoldier
17
Northern Michigan. Smelt City
I use mine for rocks and real heavy stuff. I second what Maddawg308 said.. A multifuel in a container fits perfect into one for moving around and in and out of the shop. Just pull the top cover and work on your motor or even test fire it . One hell of a trailer for the money and boy can they carry the weight. Dont forget the daisy chain option for parades creating a veteran chariot.
MDSA
12
Valdese, NC
I really prefer my 332 to a 105. Lower deck for easier loading, higher sides, tailgate lowers for a ramp, they are designed to be pulled tandem, and I think they look cool. I got 2 for $165. One is for sale.
The higher sides make it safer for hauling kids in parades (fewer bodies are lost along the parade route and parenst are usually happier).
I plan to make a mock up of a howitzer for my M200 trailer and pull the combination behind the Deuce for parades. Should resemble a cannon and its caisson from the cavalry days.
They measure about 5'X6'
I like mine
m16ty
218
Dickson,TN
Haul ammo, of course.rofl
If I could afford enough ammo to fill one up at todays prices I'd buy one.
bulldog_mack13
3/3 ACR
2,968
34
Colo Springs, CO
Anyone have a picture of a full size 4 wheeler in one? I got mine for that and its too small stock to handle a grown mans 4 wheeler.
They are good for loading heavy things in the back like you guys say with the M105 being a little bit higher. Fire wood hauler is the beeter use I have heard of someone using it for. But the box is pretty small . :wink::-D
dm22630
42
Will it fit if you leave the tailgate down? That would give you at least another foot.
2cents
BKubu
1,164
Gaithersburg, MD
I have two mint M332s in a garage. I basically visit them a couple times a month. I probably should sell one, but I am too lazy to advertise it and really would rather just enjoy looking at them than get a few hundred bucks.
