rizzo
- 8
- 38
- Port Huron, MI
moving the excavator
no, looked fine. everything was fine, a little slow, but better than expected.No close up of the rear spring pack?! How did she do?
13'8"how tall were you?
How did you get the individual axle weight measurements?
the DOT gave them to me. FYI all construction equipment is considered commercial even if it is personal.
So did that picture cost ya alot?
BAD FREIGHTTRAIN!!!!!!No locomotive in the Motor Pool. No RR tracks up here on the mountain.hmmm,how much does the 172 weigh?What is the deck height?There a 5th wheel trailer with a deck lower that can haul a 40,000lb locomotive?
trailer weighs 15,600. I cant remember the height, it is in the manualhmmm,how much does the 172 weigh?What is the deck height?There a 5th wheel trailer with a deck lower that can haul a 40,000lb locomotive?
yes low range then high. It pulled about the same as with my deuce on it, just slower in high range.You said it was slow, did you start in low range on the transfer case then split to the high range to get everything moving?
I had permits and was just wrong on a couple things. they were very fair with me.So did you find out about all the restrictions and requirments from the nice transport officer after or before you tried to move it?
wtf!fyi all construction equipment is considered commercial even if it is personal.
