panzerwillie
- 252
- 83
- miami florida
What litter and HP is the multifuel engine LDS-465 -1-A thats on the 5 ton tractors thank you
That is correct. Believe it or not, the coolant circulating through there cools the air charge. Bjorn had posted numbers here at one time.well i would think it would have a little more HP than 175 but i gues i can tweek it a little , now this engines are non intercool i see on pictures that the engine coolant runs througth the intake unless there is some type of heat exchanger but i gues it would keep it at the engine temperture![]()
Careful, there are some "experts"Mine is a 210 hp (at something crazy like 2800 rpm's). Most are direct drive. A plate on the left hand side of the dash will tell you which transmission is in it.
thank you for all the replys looking to buy a M52A2 , did some of those come with the overdrive 5th gear o only with strait 5th grear, also does anyone know the fuel filters part # looking at a truck in ohio want to make sure put some new filters for the drive to miami florida, if the deal goes througth unless i find another but all i see 4sale is M818![]()
