2009 vin info thread
CARNAC
The Envelope Please.
620
Corpus Christi, TX
M109A3 bought from Camp Grayling 6/30/09
ser# 013010488
id# 4J0354
nsn#2320000771636
Driver bumper# 1071-93
pass bumper# 1225CSB 272RSG
Thanks.
Organization:1075TH OD CO MAINT NONDIV DS Location:MARQUETTE
MICHIGAN
Nomenclature:
TRUCK VAN SHOP Model:
M109A3 NSN:
2320000771636 Serial Number:
13010488 Registration Number:
4J0354 Year of Mfg:
1966 Manufacturer:
65909 Usage Miles: 42800
Jan 05
CARNAC
620
Corpus Christi, TX
yay! just got my first deuce! it's a bobbed '67...but hercules engine # 12354301 says made 12/68. couln't find a frame vin, but just looked on sides, not front.
serial number is 4M0637
"contract number" DAAE0787069
27000 miles...not much else for numbers;
looks like barcode scanner labels on the front but painted over.
big island, hawai'i
Very little information and this information should be considered suspect since you have only provided the registration number which is painted on and can be wrong. You must confirm the serial number with the frame to be sure. No unit information on this truck.
Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2 W/W NSN:
2320000771617 Serial Number:
22521722 Registration Number:
4M0637 Year of Mfg:
1967 Manufacturer:
65909
Sep 05
CARNAC
620
Corpus Christi, TX
If you can Sir
M1008
1GCGD34J6GF351462
Can't make out bumper numbers.
1000 thanks!
Organization:130TH AV CO E MAINT Location:SALISBURY
NORTH CAROLINA
Nomenclature:
TRUCK CARGO 1-1/4T Model:
M1008 W/E NSN:
2320011236827 Serial Number:
J6GF351462 Registration Number:
NG2CKC Year of Mfg:
1986 Manufacturer:
93219 Contract Number:
DAAE07-82-C-4060
Usage Miles: 87050
Sep 05
Cucvnut
61
Carver, Oregon
Here is my
M1008
Vin#1GCGD34J7EF375377
Reg# NG1AE6
stock number#2320011236827
bought it from French camp
bumper info
AZARNG 2/180
HHS HQ 17
Big CASE
Finger.TN
1968 Kiaser Jeep M35A2 w/w
VIN, 4M2155022523191
DITD, W9025E80800004A
NSN, 2320000771617
Registration Number. n/A
Bumper numbers,
Front, HG202
Back,
Left side ,(driver side) 81CR 415
Right side, passengers side,), SD213
Thank you
SuperiorRam
Virginia Minnesota
lets try this
a. Serial Number (VIN number) ------without dashes or spaces (0123456789 correct, 0123-456789 incorrect)
b. Registration Number -----also without dashes
c. NSN without dashes -----uh, one more time, without dashes
d. Where you bought it
e. Bumper numbers if you can legibly read them
this is a pre buy from private seller in minnesota sorry didnt check frame and i wrote down this stuff off the tag on dash :
M35A2 wo/w
Id # 052519463
NSN 2320000771617
also another tag under that states
USA
nkofph
mileage
31541
the seller says he uses a title service thats all i know thanks
CARNAC
620
Corpus Christi, TX
Here is my
M1008
Reg# NG1AE6
bumper info
AZARNG 2/180
HHS HQ 17
Organization:180TH FA BN 02 HHS 155T Location:PHOENIX
ARIZONA
Nomenclature:
M1008 W/E NSN:
J7EF375377 Registration Number:
NG1AE6 Year of Mfg:
1984 Manufacturer:
DAAE07-82-C-4060
Usage Miles: 84696
In Sep 04 it was transferred to C Co, 1st Bn, 108th Aviation TX ARNG but there is no information if it was actually received.
NOTE: NEW ORGANIZATION TO DONATE TO.
CARNAC
620
Corpus Christi, TX
NSN, 2320000771617
Bumper numbers,
Front, HG202
Back,
Thank you
Organization:HHD, 415TH CHEMICAL BRIGADE Location:PELZER
SOUTH CAROLINA
Nomenclature:
M35A2 W/W NSN:
22523191 Registration Number:
4M2155 Year of Mfg:
1968 Manufacturer:
65909 Usage Miles: 33697
Info Jun 91 when it was sent to the 307th Chemical Company in Bell, CA.
CARNAC
620
Corpus Christi, TX
lets try this
M35A2 wo/w
Id # 052519463
NSN 2320000771617
USA
nkofph
mileage
31541
Organization:USPFO ACTIVITY MN ARNG Location:CP RIPLEY
MINNESOTA
Nomenclature:
M35A2 NSN:
2320000771616 Serial Number:
52519463 Registration Number:
NK0FPH Year of Mfg:
1969
Usage Miles: 31342
April 09. Prior to being turned in, it was used by HHC, 2nd Bn, 135th Infantry MN ARNG.
forgingahead
b.i., hawai'i
Nomenclature:
M35A2 W/W NSN:
4M0637 Year of Mfg:
1967 Manufacturer:
65909
Sep 05
sorry, thought i'd find a frame vin and edit before you replied.
just can't find a frame vin nor evidence of it being ground off... any tips for where to look?
i found other numbers....
the bar code sticker on the front bumper is # 511005008
8035 is hand written on fender, 403500 handwritten on inside door and on dash panel.
engine serial number is 3996168
also found designation M35 W-WN ...confused by these "W" codes;
it has evidence of a proper winch having been on it, but also has code 2320000771616, which i found to mean it was produced without winch.
could the vin have possibly been on the section of frame that got bobbed?
no papers, jungle truck, not finding the vin, i'd sure like to make sure this deuce isn't stolen!
aloha
CARNAC
620
Corpus Christi, TX
aloha
The NSN came out as a with winch truck (NSN ending in 1617). NSN ending in 1616 us a non winch truck. I would definately be looking for the serial number. It should be stamped into the metal frame just above the front axle. If it is a rebuilt A1 to A2 standards, the number will be on the passenger side. If it was an original A2 then it is on the driver side. Might be under layers of paint but it has to be there. Bobbing affects only the back end. Even removing the winch would not affect the serial number. I would be concerned at this point.
Jtheargonaut
waterford/wisconsin
052523923
04M68671
23200771616
Sparta Wi, Ft. McCoy
DAAE0670C0001 (c0ntract)
Thanks so much .. also there a broken circle on the door with an 8 inside of it. also on another truck we picked up that day. curious as if that maeking is helpful at all.
TexRdnec
Sinton, TX
052511203
04F90670
232000077167
san antonio, tx
completely painted over but those that haven't been from the same lot have started with 36
Happyland1410
Ada, Oklahoma
This may be a question that has been answered many times but I have not found it from searching.
Is it against the rules to ask about a VIN from a GL truck that has not been won yet as long as you don't identify anything about the auction? I'm guessing it is probably a no no but I thought I would ask since some of the GL info doesn't seem to match up.
Anyway, a big thanks to carnac for this service since one way or another when I do finally get a deuce I will want to get the details for it.
CARNAC
620
Corpus Christi, TX
Vin:0539-14308 Reg #04N73671 NSN:23200771616 Bought:Helena,MT DRMO: Anchorage,AK Elmendorf AFB AK Unit Bumper#172 BDE 172SPT D 18 Thank you,a great thread​
Organization:172ND CS BN ST CO FRA DET Location:FT RICHAR
ALASKA
Nomenclature:
M35A2 NSN:
53914308 Registration Number:
4N73671 Year of Mfg:
1971 Manufacturer:
65909 Usage Miles: 9673
Oct 2001
