M221
- 0
- 1
- O'Fallon MO
I'm sure this has been covered a few hundred times but I can't figure it out. I recovered my 5 ton from Jeff City MO and need to fill out the SF97. I wanted to check the vin number on the frame and I'm not sure whats is what.
The data plate shows the FSN as 2320-00-050-8984 ( 2320000508984 ). The Identification no. is 0245-10109 ( 024510109 ). This does not match the frame numbers at all.
I found numbers on both sides of the frame. On the drivers side just behind the cover for the steering box is 116643421 with a circle around an S. the next row is 607704561. On the passenger side is 116643411 with a circle around an S the next row is 607703561. All number run vertical.
Any ideas on what I should use for the vin number?
