ken326@yahoo.com
- 0
- 6
- waymart pa
Anybody know the reason why they didnt put glowplugs on the duce's?
keith,......HUH? direct injected engines have a lower comp. ratio. The I.D.I. 6.2 & 6.5 engines have 20.5-22.5 to 1 ratio, where a D.I. 5.9 cummins has a ratio of 16.1.
"A glow plug would cause issues with cold starting pressures in the cylinder head. At arctic temps, the air is very dense"
i am a litle unshure where this came from. although i hate glowplug motors, when working properly they start great in sub zero temps, powerstrokes and duramax's use them and they work fine in the cold (sometimes better than the grid used by cummins)
yes, i understand how the 'compression ignition engine' operates. however, the 6.2/6.5 engines were never classified as a 'multifuel capable engine', so i wanted to probe deeper as to how that was ascertained.
my theory:
since 6.2/6.5's don't start for jack-chet without their glow plugs functioning well, i'd say that the main differences between the two examples is the injection event itself: IDI vs DI.
the differences between these two designs is that the IDI needs high compression in order to operate, whereas, a DI engine does not. therefore, when it comes to cold weather starting, the IDI needs glow plugs. another example is the 7.3 IDI vs 7.3 DI: both engines have and need glow plugs for cold weather starting. however, the respective CR's are 21.5:1 (IDI) vs 17.5:1 (DI).
therefore, i believe the multifuel does not need the same starting aids (i.e. glow plugs) because it has an advantage: a higher-than-required compression ratio [for a DI design]. and it is this high compression ratio that makes the multi' a multifuel capable engine'.
