lavarok
- 33
- 48
- Fellsmere, FL
As with most M1010s, my "shark" had the same 12v charging issues.
I tried the wire swap trick and it didn't help, so I bit the bullet and bought a Sure Power 52210 battery equalizer and some auto reset breakers.
Yesterday, I removed the DUVAC and the related wiring. I then rewired the top alternator output to the 24v bus and the IGN wire of the top ALT to the bottom ALTs IGN wire.
Today, I finished the install by mounting the Sure Power and running 2 AWG wire for supply, output, and ground. I took some 1/0 2 pole crimp lugs and removed the wire end. I used these modified lugs to connect the 12v and 24v poles from the Sure Power to the breakers. This saved space and saved me from making two wires. I wired the 24v 80amp breaker to the 24v bus. I wired the 12v 135 amp breaker to the negative terminal of the rear battery ( same place 12v bus for vehicle gets power ). I wired the ground from the Sure Power to the ground bus.
Once done, started the truck and turned on 12v accessories. The Sure Power LED turned green telling me it was working. Perfection!
I then need to cover the breakers and the Sure Power terminals to prevent a possible accident, so I cut the old DUVAC cover and made a cover for the breakers and Sure Power lugs. I also needed a new place to mount my window washer fluid reservoir, so I screwed it into my new cover.
The only thing that might fail here is the weight of the washer fluid reservoir could break the cover over time. I plan to fashion some sort of bracket to alleviate this down the road, but for now it is working and holding up. I just won't fill it full!
Enjoy the photos. I know others have installed similar battery equalizers in their M1010s or M1028s with the DUVAC system; however, I don't think anyone has ever posted photos of the install.
