- 4,267
- 3,037
- Fort Worth, Texas
The power switch on my, soon to be, deuce does a complete 360 degree spin. Has this happened to anyone else? Any fix for it?
By what I was told it was the actual lever not the whole switch. I'll look into it.to be clear is it the handle of the switch or the switch itself that is turning? is the entire switch assembly rotating in the hole in the dash until the wiring behind it stops it, or is the part you turn that rotating on the shaft of the switch but the switch is securely mounted?
Either way, you probably need another switch, this might be a good time to get a keyed ignition switch. I think beechwood canvas had some. Beats having to chain the wheel and remove the batteries to keep joyriders away.
I plead the 5th!Fuzzy when it goes 360 does it make the truck pos ground or bipolar?
