Well, I picked up the 6/4 SO cord today and Monday I'm picking up some pin sleeve connectors to attach to the wire / transfer switch.
After getting the wire, I spent the afternoon working on the 003a.
Loose speed control:
Long story short, I got the loose speed control veneer cable tightened up (after taking it all apart / off the machine). I ended up wrapping about 4"s of 1/8" rope under the front nut that held the cable / knob on the machine. Once it was tightened down the rope added friction to the shaft keeping it from turning (kind of like a jam nut).
Setting the high / low engine speed:
My set was running at 62 Hz with the speed control all the way in and 68 Hz with it all the way out (both were not what they should be). My target was 53.3 Hz for the low (1600 rpm) and 66.6 for the high (2000 rpm). I followed the TM instructions and still couldn’t get the low speed slower than 62 Hz. After studying the governor mechanism for a bit, I ended up adjusting the bolt on the slotted shaft on the solenoid right next to the IP, which got the low speed right where it needed to be. Now my attention was turned to the high speed, even with the adjustment screw on the front of the machine all the way in I was still getting too high a speed of 68hz (however I’m not really going to worry too much about it).
Running the engine to check the Hz and volts:
Once I got everything set, I adjusted the Hz to 62 and the volts to 120, via my plug and play $22 Hz/volts meter from eBay. Prior to plugging it into the generator I had tested it with my house power and found that the Hz and volts were pretty steady. Once I plugged it into the generator, I was pleasantly surprised that the volts and Hz were rock solid, very similar to commercial power. I’ve still got to test it with a load bank for some sort to check the governor response (I’ll do that later).
Other issues:
I found that the Hz meter on the machine quit working and pegged all the way to the right (I’m not going to worry about it much as I have my plug and play meter). I noticed that there was some water / condensation in the battery charge meter, I’ll have to address that later (maybe drill a small weep hole to drain the water). I’m still waiting for my hour meter to come from Delks ($15 plus shipping).
Now it won’t start:
Here’s the big issue, after running it for an hour or so, I shut it down to show the wife how to start it. Much to my dismay, no matter how hard I tried I just couldn’t get it to start (the wife rolled her eyes). I noticed that the oil pressure would only come up to around 10 psi (running oil pressure was 30-40 psi) and I’m thinking the low oil pressure was preventing it from starting. I’m also thinking that the oil was warm and very thin causing the pressure to bleed down very quickly. I’ll try it again tomorrow after it cools down, should this be the case how do you guys get them to start when they are warm?
That’s it for now…
