nickd
- 37
- 28
- Newport, Delaware
So on the hottest day, today, I decided to address the 90W axle oil leaks on the deuce. Since I removed the rear drive shaft in an effort to prevent front tire scuffing the middle axles started to leak. The lug nuts came off easily with my 1/2" Milwaukee electric impact wrench. The bud nuts however proved to be more difficult (yes, i was turning them in the correct direction for removal). No problem moved to the 24V 3/4" drive impact gun. Nothing would budge. Last resort, pull out the deuce isssue lug wrench and the round steel handle, prop it up on a jack stand and they cracked loose with out too much strain. The rest of the job went as planned.
Just goes to show you you cant replace the basic tools that come with the truck!
