airmech3839
- 5
- 18
- Augusta, GA
Ok, I know some are waiting to hear abou balls but that stuff should be left on the playgirl website....
I was getting a small vibration in the steering wheel last night on my way home from work... It felt more like I had picked up something in the treads and it was giving me a out of balance feel at slower speeds... mind you it was very subtile... It was dark when I got home and checked the tires over looking for FOD and came up nill.... so I wondered if I was just cookoo...
I went inside and life went on.... I had forgoten about the vibration anomolly until I was halfway to work and it came on again strong and started getting worse... I was a mile from work and decided to limp it to the parking lot where I would be able to leave it if need be...
This is what I found when I got out and looked in the daylight!!
WOW!!!! I was shocked... I had completly missed checking the nuts on the wheel on the RH side(Passanger)..... I noticed a broken stud and all but one nut were loose and the one that was still down was coming loose... I was only a few more turns from in the road dead!!!
I have checked all the threads and nuts that remain and tightened them back down with some blue threadlock and I will be replacing all the studs and nuts... They are all LH thread anyway and they should be RH thread.... Just a saftey warning for all of you!!
