Recht71
- 3
- 0
- Fremont , Indiana
Got back from Gettysburg ,The Deuce run great .I put a LDS engine in it Last fall already had a aux gear box. I wanted more horsepower and torque, the LDS has that. I put m-37 on the trailer and go. We run 60mph at 2200, on the long grade and hill on the P.A turnpike the deuce can hold 5th quit bit longer then the Wildthing . In 4th pulls good Egr just under 1200 ,2200 rpm. Going east right a mile or so from the top egr just under 1300 .backed off the petal a little 1800 rpm at the top. 588 miles 77 gal. 7.6 mpg. On the way back going west put the 37 behind the chase truck they had go early. That way either truck could pull the other if somthing happened. The deuce pull all the hills in 5th no problem , when a diffrent route when got pass the hills .490 miles 62 gallons of fuel 7.9 mpg. not to much diffrent loaded or empty. Had to pull the Wildthing 14 miles and then ran up on Uncle Meat with a blown engine,pulled him to the next exit about 4 miles. For you guys putting an LDS engine in your Deuce you'll love it .
