Seabee15
- 0
- 0
- Rochester, NY
When cold won't start w/o spray...even then
Just bought a 86 6.2L m1008 cucv military truck. The seller told me that it does have a little bit of a hard time starting in the morning. What he says he does is press the accelerator half way down and turn the truck on (glow plugs). Then use Silcone Spray to spray into the air cleaner. Then he Said it should start right up.
Wrong.... Kind of
I do that, and i'll have to repeat the process 2 maybe 3 times before it starts. The seller said it could be the cold start solenoid going bad. What do you guys think? What should I check out? Fuel filter? Glow Plugs?? Or what?
Thanks
Wrong.... Kind of
Thanks
