NO LONGER Wrecked wrecker
73m819
325
gainesville, ga.
Hi, everybody knows that I wrecked the wrecker, where can I find a R/F spring hanger and 4 NEW U bolts, nuts, washers (don't know if the 800 and the 54 series are the same for these, should be)
Any other things I need to look at (I will be changing out ALL the hanger mounting bolts on the other hangers and checking them for cracks)
Thank you all for the calls to the wife when the event took place, to just to check on me. STEEL SOLDIERS is the FINEST group of people that I have ever been associated with
Recovry4x4
LLM/Member 785
1,808
GA Mountains
You need to get it back together for next year Ron. We will help any way we can. I don't want to hear that crap about it being to far either, suck it up and drive it to the rally.
73m819
325
gainesville, ga.
It WILLl be there, though NOT with NDTs on the front, speaking of tires, what is the heighth of the tires off a 915/916/920, will thay match 1200 ndts
73m819
325
gainesville, ga.
the axle fix wont be to bad, jack and blocks, chain binder & chain, the real fun is going to be getting the dampener off the snout so I can replacel the front cover/motor mount
73m819
325
gainesville, ga.
What part did the NDT tires play in this ? heavy rain or something ?
dont know, road was dry buy had light rain earler, thats why I went about 200' (WET GRASS), tires were 04 NEW, no checks, 90 psi as called for on the tire, had about 300 miles on them, when I put my hand on ALL the tires thay were HOT, could not leave my hand on them. Im NDT on the front gun shy
I would like to find some 1200 or equal OTR steer tires
2,459
Hmmm...I was waiting for this!!!!:drool::drool:
Ron...guess who has an M817 tipper donor...with EVERYTHING but the engine/trans???:twisted::twisted:
I GUESS we could be talked into picking up the heavy parts and loading them with our ITSY BITSY M816 wrecker. :cookoo:
Ya know where to come if we can help troop::beer:
73m819
325
gainesville, ga.
I went to put NEW U bolts if I can find then, what do you guys think, good take off be ok
73m819
325
gainesville, ga.
I reused on the rear, I dont went to use used on the front, to much loading, used are already stretched
CGarbee
552
Raleigh, NC
I would take one of the U-bolts off the truck with me (or from a donor) to my local heavy truck shop (such as Fleetpride) and have them make up a set of new ones... The local shop here in Raleigh charged me something like $50 last time I had a set made up (four bolts with washers and nuts...) and they did it in about fifteen minutes (including my talking to the guys...).
You've got too much riding on them to reuse old, stretched, bolts.
BFR
Rocket Surgeon
2,330
42
North Georgia
What shape/dimensions do you need? I have a set of 7/8" grade 8 ones new and unused from when I mounted the k-boom. (slight ordering error :aua: )
