- 12,195
- 319
- 0
- gainesville, ga.
A shackle is what your lift shackles are, the rears are the type your looking for, only instead of a retaining pin, you went either a pin that goes though one side and threads into the other side, this is called a screw pin style of shackle, the other type of shackle is a 4 part safety shackle, it has a special bolt that goes though both sides of the shackle with a nut that goes on it and a carter pin that locks the nut to the bolt.
If you get a shackle for this , get one that will just fit the end, this has to take the total load of the 4 parts,
example if you have a SINGLE line pull of #2500, the load on the EYE and SHACKLE is #10000
DO NOT BUY A MADE IN CHINA SHACKLE
