Heavysteven
- 10
- 0
- Hickory Flat Ga
I have a couple of question I wanted to ask while replacing the rear seals.
1. Can a standard pallet jack be used to remove the hub assembly? Anyone ever tried it.
2. If the inner bearing does not easily come off, can I pry against the seal to remove it? I would use the axle flange against the brake and leverage against the rear of the seal. Hope by prying on the seal off the bearing would come off.
Thanks
Thanks
