- 2,799
- 73
- 48
- Mesquite, NV
The kit from George aka TM America was $150 with shipping. If I remember correctly you can get either the 24 volt or the 12 volt set up individually for 75 plus shipping. If that's wrong George please correct me.
George tells me every nut and bolt I need is in the kit and it sure looks like it. I'll report back after the install.
I picked up the 24 volts alternator on the web at the link I provided in post #1. It is brand new and cost about 123 shipped. I plan to reuse the stock pulley by reaming it out with a 7/8 drill bit. It is not keyed.
Since I need one longer belt to run the 12 volt alternator I picked up all new. I got them from eBay cheap. I'll replace the compressor belt while I'm there.
I was going to use a one wire alternator I had here for the 12 volt side, but I forgot that I already installed it on my Chevelle. Instead I picked up an O'Rielys cheapie. It was 35 plus 15 for the core and 3 for the pig tail wiring. I probably should have spent another 10 dollars and bought the better one with a lifetime warranty.
The only thing we got done today was disconnecting the ground from the battery and installing the third battery for the 12 volt set up. For that I picked up a mid grade Interstate battery from the NEX for 65. I don't think I'll need that many CCAs on the 12 volt side.
So far my "kit" costs are:
Brackets 150
24 volt alt 123
12 volt alt 60
belt 8
I still need to pick up some wire to finish things off. I'm not sure how it compares to the Wolverine set up since I've only seen it in photos.
Brackets 150
24 volt alt 123
12 volt alt 60
belt 8
