Banshee365
- 14
- 0
- Ocala, FL
Pull out your slide hammer now, or drive the inner seal retainers out with a 6' pipe or rod from the other side. My slide hammer came with a couple of attachments including the 2 jaw puller. The puller jaws sucked majorly but the mount was wide enough to get behind the retained but now too big to where it wouldn't fit in the axle tube so I just used that! Had to put the mount inside the axle first, then screw the slide hammer into it. After watching the harbor freight slide hammer almost come apart from cheap metal and acting like a gorilla banging at these things they finally came out. Sweet!
