QuickSilver
- 4
- 0
- Wyoming
Bling? Good, Bad, typo?I want to do something similar with the gauges in my M1009, only probably without so much bling.
Look forward to it!I put gauges where my Gen1 and Gen2 indicator lights were. I relocated the charging indicators. I don't need a 2" diameter idiot light.. A 1/2" one works fine. I left the 4X4 and Oil pressure lights, since the oil pressure light is good for idiots (if i borrow my truck to my friends) and the 4X4 light looks BADA$$ at night. Will post up pics eventually. I used 2" cheapo backlit oil and temp gauges. Backlit in my choosing of 7 different colors tooI use blue, so it matches my radio.
Good thought. Thanks for the heads up.Just as an FYI to anyone looking to do a surface mount setup like in the first picture, off the truck they look great but once you mount them, you will see the downfall of this method. The factory dash face is angled downward so with the gauges flush mounted like this, you are not looking straight at the gauges but with them angled. This tends to look weird and can make it hard to read the smaller gauges, depending on the style you choose.
