camp9
- 9
- 18
- Yooperland, Mi
I have this happen all the time. I use air wrenches so this is what I do. The outer nut should be 1 1/2 inch. Stick a closed end wrench through the bud hole over the nut, then I put my air wrench on the end of the stud and tighten it back up, put your pb blaster on the thread and run the stud back out again, If you can't quite get the stud out, tighten it back up again and repeat. Works every time. If you can't get it just cut it off and get a new stud and nut. Good luck.
Camp
Camp
