kenz5380
- 1
- 0
- Denver, CO
I have a 1985 m1008. I've only had the truck for two weeks and i've been fighting the same issue the whole time. The starter relay went out the first day i had it and i did the recommended fix described in the sticky thread above. The relay works and the starter works, but every time i leave the truck parked for a couple of hours i come back and the batteries are drained.
I should mention that i did replace the two alternator system with a single 24 volt single wire alternator, and i'm not sure if that is the issue here. I also replaced both batteries with brand new ones thinking maybe they were just bad.
The neg. Battery cable doesn't arc when i pull it off with the engine not running so if there is a draw on the system when it is not running it is not a big one. The gauge reads in the green when i first turn off the truck but just a few minutes later it is down in the yellow and then in a couple hours they are dead.
Any ideas?
I'm looking at the alternator relays next to the starter relay under the dash thinking that they are doing something wrong with the new charging system, but electrical is not my forte and i am not certain what they even did originally.
Any ideas?
