chevyhurstolds84
- 0
- 0
- Long Island, New York
I haven't looked too far into it but it doesn't seem there's too much readily available for this big ol white engine.
yes in fact ive had many people call me mad max lolBienvenidos from CA. That's a heck of a bumper, was anyone else's first thought 'Holy Mad Max!'?
thanks for all that wisdom i shall use it the best i canIts a shame you couldn't find one with a GOOD STRONG BUMPER!
Welcome aboard young fella ... good to have you here.
About that Mo' power you was asking about ... There is NO way that you could have known ... but you asked a question that gets asked a LOT around here.
Some folks around here don't like nubes asking the same questions over and over again. It makes some of them VERY cranky!
They just can't understand why you didn't pick all this up at the moment you became a two-celled being.
anyoldways, the best thing to do if you feel another question coming on is to follow a simple 4 step process before you ask that question. That will keep the Mary Kay Ladies (don't ask) calm.
1. READ THE MANUALS. TM's have a wealth of knowledge ... you can down load them for free at places like, but not limited to: JATONKAM35s HOME ON THE WEB
2. DO A SEARCH. Think of this place as a HUGE LIBRARY, which it is. Run a through search on this forum ... and the Deuce Hot rodding forum as well.
You will find TONS of threads about boosting power in a Deuce ... which by-the-way is probably best limited to just turning up the fuel.
But I'll let you do a search for that stuff.
3. Although its not exactly relative to information per se ... go back and read the RULES of this board. Folks here are REAL touchy about the rules.
4. How long has it been since your last confession? It would probably be a REAL good idea to get on over ... and get RIGHT first.
If, after following ALL of those 4 steps you do not have the answer to your question ... THEN and only then ... should you consider bringing your question here, before the all wise and all seeing.
Otherwise ... if you feel a nube question coming on ... you just go on and blurt it on out ... one of us other whiney nube's will be happy to try to help you out.
oddshot
It's a 1986 Jeep Kaiser M35A2. The engine is original. 12.5k on the truck. It's a convertible (friend did the top). The front axle is air shift (is that what you meant?) I don't know if it has a heater yet I'll look at it next time I play with it. How long should it take to start this thing? It seems like it cranks for a while before it finally comes to life. (crank for 15 seconds about 3-4 times) Promise more pics soon!!! I don't get much time to play on the computer. Between my full time job, side work, and school. it sad that a 19 year old has no time to play.You got a white one? Most all the rest of us got green ones.
So what is it??? What year ... who built it?
Did it get rebuilt? (Hint ... look for tags that mention dates in the 1990's. You might find them on the right hand side of the engine and trans, as well as in the cab).
Heater? As a former Jersey boy ... I KNOW yer gonna need the heater out on Long Island.
Air shift?
Don't keep us guessin' ...
More pics???
oddshot
Seems a little long. Drain some fuel out of the primary fuel filter, change the filters if you have spares, but most of all before you start turn on the switch and open the fuel tank. Should hear the in-tank pump operating and some fuel returning to the tank.How long should it take to start this thing? It seems like it cranks for a while before it finally comes to life. (crank for 15 seconds about 3-4 times)
