TIGERFANS2
- 0
- 16
- Topeka, Ks
Says they are rated for 2 tons, they were for the HMMWV till they added all the armor and went to hyd. It works fine on my M101A2 trailer, goes up to 18 1/2"
Got any that fit a deuce??
Of course you PREVIEWED the item you bid on to ensure that they were jacks, and there were 300+ of them....
Oh wait, this is SS... bash GL for lying... that's always the correct answer.
Always the party pooper. Way to be
Ive made an a** out of myself several times, Im used to it.MAN ! I was choking on my cold one here, not wanting to look like an as* !
We all know the end game was a snarky comment along the lines of 'GL is incompetent if they cannot tell the difference between 64 and 300'.Always the party pooper. Way to be
Probably got fired for doing it.GL has no actual procedure to count over 10. Although I'm sure some have figured out to remove shoes to go higher.
No way am I bashing GL for the count. The # in there is not GL's it is the supply Sgt or DRMO person that lotted it and sent it to GL. I should have inspected but when I was doing a 0800 PU out there I was told by the New GL woman that I did not make an appointment to inspect? Also as I posted earlier I bid on the wrong lot so this is all on me.Of course you PREVIEWED the item you bid on to ensure that they were jacks, and there were 300+ of them....
