Boss Doug
- 1
- 0
- St. Petersburg Fl
The bottom of the goat column is female spline. How did you attach a u-joint? A small section of splined shaft?the upper column from a goat is easy to use as well and tnj has them real cheap. gives you complete horn setup, just need to put u-joint on bottom end of shaft.
tom
Can you post a copy of the CAD drawing?
