JasonS
- 139
- 63
- Eastern SD
I started my power steering conversion this weekend. I am using the Ross HF54 power steering box, the 8.5" pitman arm, 5-ton pump, and a custom drag link.
I did not have to move the engine to remove the old steering box. I just pulled the column, removed the cover, pounded out the sector shaft, and removed the box.
I had the frame stiffener holes machined locally using the CAD drawing Jon created. I lined up the frame stiffener to the old steering holes and enlarged/drilled the holes. I used a homemade compass to draw the hole in the frame for the HF54 box and cut it with a torch. The opening in the frame stiffener had to be enlarged for my steering box which had a stepped sector shaft.
I had the drag link made locally which fits commonly available tierod ends. It is 1018 (mild steel) but the OD is 1-5/8" which results in a minimum wall thickness of 1/4".
More to follow in a few weeks....
