- 2,459
- Columbus, Georgia
Is it free?... Bring it on Bro!All y'all need more motors? A friend has one I can bring to see if it's worth a save.
Tell me what ya need Bro...should I bring the backhoe??
I figured I might have to toss the front wheels back on if this sloooooow poke does not get the front brakes done by "injection" time - can always roll er forward a tad bit - I know I am not allowed to run powered objects - so hitting anything is not a possibility - but then again I fall a lot.
Bobcat - HEY - !!!!!!!!!!! Did I mention that big arse stump I needed shoved outta the way - and then there are those two piles of wood chips still lurking around jumpin
I am hoping to get something set up and finished before the troopers arive - Its a surprise for ya all down there - even if you don;t like it - you will have to be the one to remove it - cause I plan on putting in on permanent.
What happened to that stuff Dave?? Was it removed here?Just had to do it - fill area as well off the tank - gotta go hunting for parts. missing the tank strap bolts to connect the straps - missing the fuel pick up screws Otherwise this baby would be installed. Also missing the angled piping to the fuel
Taking the brake shoes to get relined tomorrow - have to order the front wheel cylinders from John up at Midwest Military.
Tire pictures later for ya - they smell like new RUBBER - I would add a scratch and sniff to the tire pics when I do them for ya - but I do not know how to add that.
Why does this sound like the grumpy old Crown Royal bandit, who we have come to know. I really wish that I was closer to you lot, so I could shake a few hands, drool about your toys, and loose the cap off of a Big bottle of CR, while spapping stories!I will make sure you have what you need Bro.
