The Air brake tubing works well, but you have to use the insert too.
I agree here is what i bought from McMaster when i did mine. I did not use all of it so if your on a tight budget you don't have to order all this.
5097T61825 Ft.D.o.t. Choose-a-color Nylon Tubing For Air, Nonreinforced,.17"id,1/4"od, .040"wall,yellow,25'l2
5097T66225 Ft.D.o.t. Choose-a-color Nylon Tubing For Air, Reinforced,.251"id, 3/8"od,.062"wall, Yellow, 25'l3
51835K2811 PackBrass Dot Compression Tube Fit For Nylon Tube, Sleeve For 1/4" Tube Od4
51835K2821 PackBrass Dot Compression Tube Fit For Nylon Tube, Sleeve For 3/8" Tube Od5
51835K2911 PackBrass Dot Compression Tube Fit For Nylon Tube, Nut For 1/4" Tube Od6
51835K2921 PackBrass Dot Compression Tube Fit For Nylon Tube, Nut For 3/8" Tube Od7
8359K11325 Ft.High-strength Clear Nylon Tubing, .096" Id, 1/8" Od, .014" Wall Thickness, 25'l8
50915K2411 PackCopper Tube Support For 1/8" Tube Od9
50915K2451 PackStandard Brass Compression Tube Fitting, Tube Support For 3/8" Tube Od10
50915K2431 PackStandard Brass Compression Tube Fitting, Tube Support For 1/4" Tube Od
