Deuce road tractor conversion
RAYZER
59
sanford/florida
Well,i needed a tractor to pull my m146 trailor, i wanted to stick with a 2.5 ton for a few reasons: the m146 was designed to be pulled by a deuce, multi fuel capability and i allready had the deuce ww and couldn't find a m275a2 within reach.
So i bought all the components off the back of a junk 5 ton cheap and went to town, i put the 5th wheel just foward of center of tandem,removed 1 cross member,cut 12" off the back of the frame,installed the original pintle cross member back in,took 8" out of the spare tire rack ,used grade 8 bolts to put everything together.
A few things i still need to do: find some m818 tail light mounts, plumb in the air lines and trolly brake (still trying to figure that out).
pics coming!
mikey
39
Lake Como, PA
I am constantly amazed with some of the members on this site and the things they can do. As a non mechanic whose biggest and most proud achievement to date has been installing spin on fuel and oil filters, these are the types of projects that leave me in awe.
Looks sweet OP.
rosco
30
Delta Junction, Alaska
Great job. Especially the part with two fuel tanks. After market mud flaps are important too, in case you have to "bob tail".
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Looks good Ray. There is a air system schematic in the back of the 361-20. Appendix E I believe. Follow the one for the M275A2. Attaching that TM (as long as its not too large)
Ooops, it was too large.
Tow4
646
Orlando, FL
Looking good Ray.
Is the fellow that did the conversion going to plumb the air and fuel for you? It looks like he did a really nice job on everything. I'm sure the TM for the M275 will have a diagram for the air system; the fuel should be straight forward.
Somebody already mentioned mud flaps. Most states (like FL) require them if you don't have a trailer attached. Make sure you get removable ones or be sure they will clear the trailer landing gear.
Keep the pictures coming! :beer:
spicergear
27
Millerstown, PA
Rayzor, I just removed the spare tire rack from my 5 ton tractor last night. Is there any reason other than having the one storage compartment to the driver's side that you put it on spun 180*?
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Tom, are you sure yours was opposite of Rayzers? Maccus has his reversed to look more like an M48.
armytruck63
10
Redlands, CA
I would think the spare should be on the passenger side of the truck. Imagine you are changing a tire on the side of the road and the spare gets away from you. Which is better, having it roll into some bushes, or having it roll out into traffic?
The spare is mounted in the correct direction also, with the safety ring facing away from the co-driver's seat.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
I would think the spare should be on the passenger side of the truck. Imagine you are changing a tire on the side of the road and the spare gets away from you. Which is better, having it roll into some bushes, or having it roll out into traffic?QUOTE]
The M48 was the only one I can think of with the tire on the drivers side. I figure after removing one on the side of the road they got smart and put the others (dumps included) on the passenger side. Maccus' spare carrier is also off a M215 IIRC.
73m819
323
gainesville, ga.
The only thing is the rear cross member, on the 5t tractor, the rear cross member is DROPED in the center with a corresponding droped pintle, to clear a LOW trailer pin as it hits low on the ramps, the same with the extended 2 1/2 ramps that will lift the trailer above the rear frame member. SO be careful, I have seen more then one fifth wheel pin hung up in the rear cross member on civi trucks.
spicergear
27
Millerstown, PA
Yep, the M931A2 has the tire on the driver's side. Literally removed it last night. Didn't know the M818's had the tire on the pass's side. At the base of the little tire jib dealie you can see where the valves and trailer air lines come up and stow above. I pulled the 1400x20 out before picking it off with the tractor. Only took me about 12' to 15' to stop it rolling.
