- 26,246
- 1,179
- NY
Found this, just replacement. No adjustment listed.
I don't see anything in my -34 Tm.
DH, The level wind end adjustments are critical, see adjustment referenced on attached picture. There is a stop for each end.
Make sure that 1.5" is enough to install the shaft and allow you to change sheer pins.Today, I looked at those trolly stops. Mine has them and they are out about 2". I Came to the same conclusion(before posting this thread) that Spicergear has). I want to see what he has done to correct that issue.
Squirt truck, are you saying you have no issues with your level winder and are completely happy with it's performance and function, as it is in stock form?
Also, I took a total PTO shaft length measurement today(to give to the shop). 80" total length installed, from one end to the other. There looks to be about an inch and a quarter available to collapse it)on the splines) to install it.
