hemichallenger
- 2
- 0
- deland fl
This time it was on a a3.
I loaded about 10000 pounds of scrap iron and was on the way to dump it and the petal went to the floor. I have not had any doubt the the brakes were working at 100 percent till the petal met the floor. After I got stopped and opened the hood pulled the brake fluid caps off both sides were full but air was bubbling from both sides. I drained the air tanks but air had entered the system so I could not pump them up. I started it and built up the air and it started bubbling again so I drained the air tanks and pulled the air lines off both air packs and sprayed pb blaster in the lines and put them back on and started it up and it was not bubbling. I then had to bleed the brakes to get any type of petal. I went and got rid of the load and drove back to the shop in discust.
