tbearatkin
- 24
- 18
- SouthWestTennessee
So driving down the road the last week and I had a sudden loss of power going up hills. First stop light I came to my M1009 died. I coasted around the corner put it in neutral and it started right up. I was almost home but the rest of the way home no power going up hills. It stalled one more time going around a corner but started right back up. It stalled again as I turned into the driveway. (two right hand turns and one left hand turn)
I changed out my fuel filter. (bled all the air out of the system at the filter and did take the pink wire off the IP).
Still low power. I cleaned the return valve but still low power.
I took off the air filter and ran it around the block without it and still low power so a dirty air filter is not the problem.
When I take the pink wire off the IP and turn on the ignition and then put the pink wire back on I do hear it clicking.
So now I have to decide what next and what will be the least painful.
1. I have 3/4 tank of diesel so I will have to siphon quite a bit out to drop the tank to check the filter sock. Does not sound like a fun job. But I will first check the fuel flow per the manual and see if I have a good flow rate 1/2 pint of fuel in container after 15 seconds of cranking. If I do then I do not think the issue is at my fuel tank.
2. Order up a new/rebuilt injector fuel pump and while I am at it replace the injectors. Truck has 60,000 miles on it.
Am I missing something I see nothing in the manuals about troubleshooting the IP while on the truck the 34 manual only describes bench testing it with equipment not normally found in a home shop.
