how does the m1009 run on waste motor oil
jeeplvr247
10
Ferndale, MI
Some people run a wmo/diesel blend without a problem but I have always figured that they didn't write "diesel fuel only" on the dash out of boredom so I pony up the extra dough and buy the diesel. Just my two cents worth
jdeoliveira74
wilmington nc
I have been doing a ton of research on this. From what I have found the IP pump needs the lubricity that the new diesel fuel doesnt give it. As long as you heat it to the correct temp 170 degrees at the injectors you should be good to go. I hear it runs quieter and smoother! I hear atf smokes like a bi*&h
Reverend Evil
Crestview/Florida
I add atf to my fuel about a quart to every 5 gallons . but i also have a good supply of used atf. it helps a little and it has been discused on here in other threads about mixing your fuels. you need a blenders liscens to do this (i dont have one just running on luck) at least thats what i have been told. but the 6.2 injection pump wont like wmo or wvo .it is to thick on its own.
chevyCUCV
Massachusetts
In response to the original question.
Diesel and oil are close to eachother. Oil has more btu's.
Dump in in your tank.
Start your vehicle
The end
pgwaldner
Haleyville, Alabama
I run it mixed with diesel. Helps lube the system not that ULS diesel is all that is available. It does run stronger with the WMO but you can smell the difference when behind it. Just make sure it has NO water in it. Technically taxes have already been paid on the oil when it was bought, I am using it as an additive just like any other fuel additive (ie: wynn's, stp, octane boost, cetalyne boost, etc.)
porkysplace
1,494
mid- michigan
It might have had sales tax on it when bought but road use tax was not paid on motor oil .
Chief_919
103
Western NC
Up to 50% in the summer, and 30% in the winter have been no problem for me.
Runs smoother and quieter in fact.
Just filter it well.
kipman
15
Lancaster Ohio
I have a get of jail free card, sent the State of Ohio the road tax for x amount of non taxed fuel I use per year, now would love to get pulled over and have my tank dipped.
islandguydon
787
Michigan
6.2 on wmo...?
how does the blazer run on wmo
I guess I was diesel green at some point in my life.
dmilkman589 Check this out.
The same engine is in a M-1008, M-1009 and a M-1028.
A GM Diesel 6.2 is a diesel engine, not a multi-fuel. I fill up with diesel and 1 quart of 20/50 MO to help lube the fp. This engine is and was designed to run on diesel fuel not ATF, UMO,E-85, or any other fuels.
After all it's your truck and you will do with it as you see fit. IMHO, I would only use a fuel recommended by the manufacture. 2cents
