New Acquisition, M1097R1 Helmet Top
KKroger
29
13
KC MO
6.5L NA 3L80, Runs Great, Drives Great, Price paid was great. Just delivered yesterday.
Transmission Fluid was Clean and Red, Oil was clean and clear, coolant green, have not had time or weather in the last 24 hours to do anything other than test drive and bring it home. single digits suck.
60dcc209-6985-4b15-be39-3b0809ff7a4f.jpg4c0145ab-ea91-4f84-8756-2e4dfcceb48d.jpg7ae6cfe0-b92b-4cc9-8af3-e952538b8b39.jpga66b4ff7-866d-48a7-88ce-264a9190b8aa.jpg8ac2c0dd-763d-482d-8d32-1974a74824b4.jpg944bdb73-e090-4b5a-aec1-f3e3d86d3221.jpg
20,379
View attachment 939421View attachment 939422View attachment 939423View attachment 939424View attachment 939425View attachment 939426
Welcome to the Outfit!
Be sure to at least download the -10 TM Technical Manual so you don't smoke your start box! It isn't a good read, but just perusing the book will save you plenty of money.
Coug
4,554
Olympia/WA
We also have them in the TM section here on this site as well
The M1097R1 are an oddball case that aren't specifically listed in the manuals.
When looking through the manuals you will want to use the M1097A1 listed parts and procedures for your 3 speed truck.
KKroger
29
13
KC MO
Swapped the start switch to a keyed switch today... easy stuff, removed that orange ratchet strap... Drivers side rear door the latch had been set and not re-opened. then evidently GI Joe BEAT it shut and strapped it down. the post was bent in, I hung a box end on it and bent it back out. door works fine. I already ordered prophylactically two latches, a set of "Mushroom" type posts and Double locking door handles. so once they arrive I will be set on that front.
Milcommoguy
2,352
Rosamond, CA
Swapped the start switch to a keyed switch today... easy stuff.... Don't lose the military one.
Could be a big problem, tomorrow. CAMO
KKroger
29
13
KC MO
Pretty sure it wasn't the key switch... the belts departed and the alternator pully is crap and the keyway is ground out to set the wrong woodruff key at an angle and it allowed the pulley to walk back and forth and waller out a place in the pulley... New Pulley on the way and I'll pull the alternator and see if I can mill a keyway for a square key in there. Had a buddy who is the KING of half assed suggest drilling and tapping the pulley for set screws... sigh...
