Mep 804b Alternator regulator
jmenende
413
Puerto Rico
Good day folks.
Been having a hard time finding the regulator part number for the alternator on my 804b. Anyone have any leads?
Thanks
LuckeyD
96
13
Vilseck, Germany
I recommend you research posts Guyfang posted. He posted everything you need. Step 1; What type do you have, TRC or Libby. (TRC black or green Libby regulator). only replace with same type. Step 2: PN: 19870 is TRC, and PN: 122-3054 is Libby. This is just the regulator. DLA Avaition put together kits after countless requests from LARs that contain everything you need to change from one to the other, but no Part Number you can actually get outside the Military system. The following are different between the two: Regulator, Voltage adjust rheostat, R-16 located behind the green CKTBKR panel, and the power sensing transformer. Libby trans have black terminal boards and TRC has just connecting loop terminals. Mixed up and you will have EXPENSIVE issues.
jmenende
413
Puerto Rico
Thank you for attempting to help but im not talking about voltage regulator for the generator. My request is for the regulator on the alternator made by hitachi.
LuckeyD
96
13
Vilseck, Germany
OK, there was no parts they put in the Gen manual or engine manual for the Battery charging alternator regulator from Hitachi on the B model. It was a 35 AMP battery charging alternator that put out too much current popping the 30 AMP battery charging fuse or 25A breaker causing a free running battery charging alternator that burnt out the internal regulator. It sensed a continual lowering of battery voltage and thus went into 100% charge rate and over heated. Some folks took the alternator apart and took the regulator to a local car parts place. Others just replaced the alternator being careful to also change the pulley carefully and they measured the alternator shaft. Big fan on a narrow belt so keep it tight and the belt stretches. We recommended to ensure batteries were fully charged to prevent this battery charging issue. Didn't work. I attached a file. There is a lower rated amperage alternator that works.
