mrandig
- 111
- 33
- Houston, TX
I was able to accomplish a few other items this week.
Fuel filter and water separator - this is a pain to get to.
Remove the two upper hoses (fuel inlet / outlet), disconnect the transducer, remove that lower hose (drain), and unscrew the bolt clamping the bracket together. Bend open the bracket. Bend it open a lot*, then remove the fuel filter housing.
*Note - there's probably a gentler way to do this, but this way works for me.
Access the fuel filter element and water separator by removing the top cover - there's three bolts at the top of the housing. In my case, neither the filter nor water separator looked particularly bad, but now it's done; I don't have to wonder if they need to be changed.
Replace the fuel filter, water separator and o-ring, then replace the cover (50-60 in/lbs.) and reinstall the assembly back into the bracket. A small pair of vice grips helps to clamp the bracket together until it is screwed tight. Reconnect the transducer as well as all three of the hoses (10-20 in/lbs.).
Finally, the fuel filter will need to be bled. I can't perform this step right now, as I don't have batteries installed and it requires the engine to be turned over a few times. I'll do this once I get further along with my repairs.
