In tank fuel pump substitute for M35
msgjd
3,614
upstate ny
If you clean/rebuild your original in-tank pump, make sure to use submersible fuel hose and not regular hose… made that mistake once and it didn’t take long to swell up & cut off fuel flow as well as become a nasty mess to replace.
Were you able to buy the fuel-rated hose per the foot?
About 6yrs ago when i replaced the one in the M49A2C i called around and only one place had the hose on hand.. It only came as a 10ft coil . I feel severe residual monetary pain now that i mentioned it . IIRC it was around $100. o_O
I should pay my dues and sell the remaining 8 or 9 feet by the foot on here
Adrok
185
33
Rochester NY
Not for nothing, but since needing to repair my sending pump, I've hoarded and repaired them when given the opportunity. A lot of small parts actually.
A rough clean and letting sit in a cleaning solvent has worked well for the sending pumps and master cylinder.
Evaporust pretty cheap on amazon or Harbor Freight.
Like silverstate55 said, use the right material.
I've spent too long and created too many problems cutting corners and being cheap
Cheers
silverstate55
Unemployable
2,124
1,074
UT
Yes, I had to buy 2 feet, IIRC it was from the Parker dealer in Las Vegas (NV). At the time it was around $35/ft.
