1996 M1097A2 Self induced charging issue
DFink
Roanoke, Virginia
Quick back story.... Moving the batteries under the hood, they are still sitting/ hooked up in the passenger side. Military dash mount has been removed. Gauges, run/start switch, lights switch all are hanging loose. Started the truck the other day and the charger is maxed out. I know I either have a short or a wire not connected.
I am trying to figure out the FIELD and SENSE wire. Thanks for the help!!!
TOBASH
3,833
Brooklyn, NY
TMs are free and contain wiring diagrams.
They are located above in the stickies AND on the main Steel Soldiers index page in a TM section.
Retiredwarhorses
4,397
Brentwood, Calif
if a gauge is maxed out, you have a wire disconnected, the voltage gauge only has 2 wires, 24v and ground, use a multimeter
to determine your true alternator output.
DFink
Roanoke, Virginia
Finally, I have a chance today to check some voltages.
Key on engine not running
+14 V 13.5vdc
AC 0vdc
Ign 24.5vdc
Engine running
14 V 17vdc
AC 13vdc
Ign 32vdc
I've went through the wiring and haven't found anything obvious yet. Tested the alternator and regulator with the Niehoff PDF and it looks like everything is okay.
Retiredwarhorses
4,397
Brentwood, Calif
+14 V 13.5vdc
AC 0vdc
Ign 24.5vdc
Engine running
14 V 17vdc
AC 13vdc
Ign 32vdc
32vdc on the IGN? You have a bad regulator
17vdc on the 14v Tap? Bad regulator
AC is a signal….not voltage.
what is the running battery voltage? I would venture to guess 32vdc, same as IGN…. bad regulator.
86humv
534
Texas
Yep batteries running voltage is 32. I guess it is time to find an inexpensive regulator or start looking at converting to 12v
I have tested N3135 regulators for the 200 amp Alt. available.
86humv
534
Texas
At the going rate for a tested/known good regulator I can buy a 12vdc alternator and starter. I know there is a lot more to it but right now I am weighing my options
Reg is 250 plus ship.
Retiredwarhorses
4,397
Brentwood, Calif
GL with all that…going 12v’s is a PITA at best, you will need do a bit more than just an alternator and a starter.
