- 994
- 1,827
- 93
- Colorado
I drove 40 miles after an easy start then parked for an hour. Tank was half full. 70F outside. Upon trying to start back up, the engine would kick over briefly then die, tried half dozen times and each time was the same. No codes or check engine light. I thought maybe my tank vent was clogged so I opened the fill cap. Tried cranking again and it was still skipping and dying. Then About 30 seconds of continuous cranking and it began kicking over bit by bit then finally started but was barely rolling over. Then it slowly built up to full idle over about 10 seconds.
Drove 40 miles home and no issues.
I'm wondering if the tank vent could cause this?
Luckily those group 65 AGMs were fully charged.
