Gen1 trouble
AllAmerican505
Arizona
Just need to put your voltmeter in between and read what it says. Figure f9 in the tm shows the connection the brown wire goes through the firewall on. Back probing that is very difficult so you'd have to unbolt it to test it from the block to the alternator and the block to the bulb.
Sent from my SM-S906U using Tapatalk
I just tested from the alt plug brown to build and has continuity.
WWRD99
1,835
York Pa
So you do have continuity from the bulb to the alternator plug. So you have to have power at the alternator plug then since you have power at the bulb. They're on the same wire. You can't have both and no power at the plug. It's not possible.
AllAmerican505
Arizona
I agree 100% I’m chasing my tail and a new alternator and still 26.4 ish volts.
Does the light even come on with key on ever?
It’s all powered but nothing in the brown wire key on or off.
RattleSnack
60
Ford City, PA
I've been pulling up wiring diagrams and reviewing pics of cluster circuit boards this whole time....
...but I'm definitely stumped now. :unsure: Something just isn't adding up.
AllAmerican505
Arizona
...but i'm definitely stumped now. :unsure:
Ghost in the machine
I need to figure this out as I want the 24v and slave cable option.
The longer this takes the less likely I will leave it 24volt
WWRD99
1,835
York Pa
The light comes on with the key, and the regulator, brown wire, is the ground. Once you start it, the ground is gone because the regulator is using the power. Where are you getting a ground for your meter checking the brown wire at the alternator? Don't use the battery...use the block or body.
AllAmerican505
Arizona
I will try more tomorrow
Tow4
669
Orlando, FL
Actually, once the alternator starts generating, there is B+ at that terminal which means there is B+ on both sides of the bulb. When the alternator is not working, that terminal is low (ground) and the bulb lights. If you ground regulator terminal #1, the alternator light should come on.
You can test the alternator on the truck to be sure it's not the problem. Click the link below.
Testing the alternator on the vehicle.
WWRD99
1,835
York Pa
Pretty sure that's what I said. No need to try and nit pick. Actually.
Tow4
669
Orlando, FL
Not trying to nit pick. The regulator is not using the power. When you explain things, it is better to be accurate.
AllAmerican505
Arizona
update still no power at brown wire and no charge.
I donno unless someone can help me figure it out the 24volt system is going the dodo bird.
Complete horse pucky.
No one sells good harness’s has to be cucv specific.
Now I don’t even start from ignition anymore so must have screwed the pooch on the coloum ignition
WWRD99
1,835
York Pa
Ok...get away from thinking this is a 24 volt problem. It's not. It's a simple 12 volt alternator that's used in many cars made in the 80s. If you lost key on power you probably popped a fuse under the dash.
