Ok, I screwed up (again).I should have taken pictures and I would not have these issues.
I removed the starter and put it back, but now the starter seems to run when in the run position! It did not do this before I started, so I am fairly confident it is the wiring at the starter that I just did not hook back up correctly, and nothing to do with the switch.
So I was going off this part of the electrical diagram:
So I check my wiring of course. The starter seems to have three terminals:
Thanks in advance!
- Huge +24 Constant connector with a strap that runs up to the solenoid. To that I have 6A, 81A, 81B connected to the and it has constant +24V as expected.
- Large Ground connector that has leads 3D, 7A and has constant ground
- Third connector is the little screw on the solenoid. It had, I think, Two wire connected to it before - 74A&B. 74A, the larger gauge wire, has +24V when the switch is in the run position? That does not seem right? I would think it would have +24 when in the Start position only? The other lead is not energized when in the run position.
Thanks in advance!
