MA MEP-802A, MEP-803A WiFi 2-Wire Remote Start Parameter Monitoring System
kloppk
3,973
Pepperell, Massachusetts
Remote Start Controller Kits
For use in MEP-802A, MEP803A, MEP-804A, MEP-804B, MEP805A & MEP-806A Generators
WiFi Remote Control & 2-Wire Start/Stop
Features include:
· Remote genset Start/Stop via WIFI via cell phone, laptop, tablet
· Direct WiFi communication. No router needed. Works during power failures. (Version available with home WiFi network integration)
· 300 foot plus WiFi range. Password protected
· Browser display of all engine and generator operating parameters on remote WIFI device. Parameters nearing extremes are highlighted in red text.
· Ambient Temperature
· Battery Voltage
· AC Voltage
· AC Output Frequency readings to 0.1 Hz
· %Load
· Fuel Level
· Coolant Temperature
· Oil Pressure
· Remotely Enable and Disable the Auxiliary Fuel Pump
· Remote control of the Contactor with the Contactor state displayed
· User calibration of all parameters
· Data Logging of all parameters as well as engine hours and Start/Stop count. Min, Average & Max values logged every 10 seconds.
· Two wire remote Start/Stop for use with ATS or other contact closure
· Transfer between WIFI and Manual control while running
· Automatic Pre-Heat below 40 degrees F
Additional features
· User programmable durations and delays for all phases of start up and shutdown. Separate delay settings for WiFi Start/Stop and 2 Wire Start/Stop
· Pre-Heat duration
· Fuel System prime duration
· Cranking duration
· Warm up
· Stop command to contactor open delay
· Cool down delay
· MIL Spec Wire
· Antenna and connector are IP65 rated for water resistance.
· Retains full manual control of the genset
· Controller is conformally coated to seal out moisture.
· Includes Controller, wire harness, all hardware for installation & manual
· 1 year warranty
** New info updated 9/14/2021
Two versions are now available.
1)Version 1 (original) does NOT use an existing WiFi network such as a home router. WiFi communication is direct from the controller to your WiFi enabled device with a browser. The controller is set up as a WiFi Access Point.
2) Version 2 can connect to your homes WiFi network and the controller can be accessed via any device with a browser on your home's WiFi network. The controller is set up as a WiFi Station. If you set up "port forwarding" on your router you can access the Remote Start from anywhere on the internet.
I personally assemble each of the Controllers and wire harness’s. Once built each Controller is tested in a generator simulator and then installed in an MEP-802A, tested and initially calibrated to assure a defect free unit.
Users Manual --> Installation & Users Manual
Ordering Information
Cost: $525 Includes USPS Priority Shipping in the US
PayPal & Checks accepted. Quantity discounts available
To order email me at: kurtklopp@gmail.com
Be sure to include the following information:
1) Name & Mailing Address
2) Payment Method
4) PayPal email address if using PayPal
Controller mounted on control cube
Controller Circuit Card Assembly
Pre-Assembled wire harness
Installation & Users Manual plus mounting hardware
Sample phone screen when running
Sample phone screen of Min, Av, Max statistics table
Sample phone screen of calibration adjustment
Feel free to email me with any questions!
kloppk
3,973
** New info 10/31/2020
