1028A3 Owners?
FMJ
37
Las Cruces, NM
Guys,
I need you to look at the following pics. I found an 80's Chev in the junkyard that had a D70 in the back with the sway bar assembly, and one overload spring. I also found the missing fuel transfer valve, switch, and associated wiring. Is this the correct rear sway bar for the A3? I got the whole bunch for $100.00 My truck has the D70, but no overloads, sway bar, or fuel transfer switch...
Also included are some pics of my 250G shelter that I am going to gut and convert into a small camper.
Ed
NDT
6,532
Camp Wood/LC, TX
Did you just win that shelter? I think it was sitting next to my M880 at Kirtland. The 880 just arrived this morning. Love your rust free NM trucks!
FMJ
37
Las Cruces, NM
Thanks, Yeah got it at Kirtland. That 880 had a siezed motor I think...guy said they "found" it somewhere....
Hammer
398
Winlock, WA
Actually, some 14B hubs WILL fit right on there.
Well, I put some SRW 14B hubs on my 70HD axle to widen the WMS.
FMJ
37
Las Cruces, NM
Butttttt.......................................does it run yet???????????????????????????????????????????
:razz:
Soon as you sell me a "good" 6.2........:p
I've got an unknown in a parts truck indicating 60k on the Odo.....oil and anti- freeze look good...
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
I would suspect those are all the right stuff you need. The only thing you will be missing (unless your truck happens to have them for some reason?) are the brackets that the sway bar end links attach to.
I will tell you that I have seen conversions without these brackets and they basically put the end links in a hole in the bottom of the frame about where the bracket went. I'm not sure if that hole was factory or not. I might have a pic of the brackets from my kit somewhere, but they should be on the truck you got these parts from. Problem is cutting the rivets...:(
FMJ
37
Las Cruces, NM
On the "donor" truck, they went into holes in the frame. :?:
CUCVFAN
47
Jarrettsville, MD
In that case, I would not worry about it. Install it as it was. It must have been a design change at some point?
jimbo*
Roswell, New Mexico
I have a good 6.2, 54K on it. I thought you were going with a 5.9?????
I will check my parts truck for the stabilzer brackets; I'm pretty sure they're on there.
