I have 3 trucks that all have the same problem going on with them. The mileage flashes, the no charge light comes on, the 24v gauge sits at 0 and the oil pressure gauge sits at 0.
the 12v gauge also sits low but if I put the truck in gear it will jump up to 14v and the no charge light will go off. Everything will still not work though. One truck I got to come back to acting normal after reading on here to disconnect the ctis harness but it could just of been a fluke.
just about everything charging wise has been replaced. Fresh batteries, alternator and regulator, load bank, and mmdc have been swapped with a known good.
has anyone found a fix or had this problem before?
