11.00x20 Tubes & Flaps
dfanders
Yardville/NJ
Gents,
We have just replaced 8 tires on a M52. We are llloking to get the spares set up with a single spare tire and some tubes & flaps. Can anyone suggest a place to get 11.00x20 tubes & flaps? I tried the website listed under old tube threads, but it is down ( www.innertubes.net)
Can someone tell me what a "flap" is - I don't think i have seenone before.
Any suggestions on tools that will be needed to change a tire in the field , assuming you already have the spare on , and you get a nail, and just need a new tube in...yes this has happened, so i want to be prepared.
Cheers,
David
rmgill
14
Decatur, Ga
DAvid, try a commercial truck tire place nearby. You should be able to order them and have them in a few days. I bought all new 1100 tubes for my deuce and used those.
The flaps are probably just fine. I have several and it takes a LOT to have one fail. The flaps are just a rubber ring that fits inside the tire and separates the inner tube from the rim. Here's a site showing the assembly of combat rims which are divided disk rims. They're similar but different from the deuce/5 ton rims but more or less the same assembly. The key thing is how the flaps fit into the tire to prevent the tube from rubbing against the metal.
jasonjc
288
Gravette Ar.
I had a flap chew up a new tube. Check them real well before reuseing them. As for tool you will need 2 lock ring tools and a bead breaking hammer or side hammer. A spray bottle with soapy water will help alot also.
One more thing, the tire shop I use alot will put a patch on the tire where the hole is. That will help keep stuff from getting in between the tube and tire.
