12/24 volt fleet style charger with slave port
Cape Coastie
CWO4 ENG/MSS, USCG, RET.
528
124
Sandwich, MA
So I decided I wanted to have a 24 volt charger handy and found this unit on A-----. Thought I might as well come up.with a way to charge directly to the truck through the slave port and came up with is setup. Haven't tried to jump start or charge yet but it runs my 1/2" robotool on the jump start setting. Hope it holds up and works well.IMG_20180521_180014.jpgIMG_20180521_175911.jpg
rchalmers3
30
Irmo, South Carolina
That's a nice solution, Coastie. I'm interested to know where you located the external mount box for the slave port receptacle.
I tried searching for the "Monster battery charger" but all I come up with are small units for providing USB power. Would you please give us the charger part number?
Rick
Andyrv6av8r
457
Spartanburg,SC
Cape Coastie
528
124
Sandwich, MA
Here is the screen shot from Amazon for the charger. The box I used is a heavy duty unit I found laying around at work. It is heavy wall plastic. The cover is just a modified wall cover . Had to drill out the back for the wiring. Like I said before I haven't tried it charging or under a heavy load. Hope it holds up.
