12bolt run flats with 24bolt rims
jrpontiac
14
Spokane Wa
I just picked up some 24 bolt rims and inserts. My plan was to leave my current 12 bolt rim inserts in the tires and swap the rims. Will this work. My new inserts are 3 piece aluminum inserts. Mfg 6/2015. I looked around a little bit on the web and didn't see any pictures of them. I guessing my current inserts are the rubber kind.
richingalveston
120
galveston/Texas
I think it will work but I believe if you run the inserts the 24 bolt ones are much better to run. Less weight and balance much better.
I don't have any but I did research them when considering to use them and that is what I learned. I also learned that I do not need them.
Others may know more.
Rich
Retiredwarhorses
4,061
Brentwood, Calif
Never seen those run flats...the military uses 1 piece rubber run flats in all newer 12 and 24 bolts rims. They act as a head lock as well.
the 8 bolt rim uses a magnesium 2 piece run flat, not for use in the newer rims.
jrpontiac
14
Spokane Wa
I watched them dismount some new mtr tires from them. Must be the most current version runflats. As mentioned mfg date is 6/2015. Rims had never been mounted on a rig and tires were new. Seller wanted the tires for his 1/2 ton chevy. Had no use for the rims.
richingalveston
120
galveston/Texas
I would try them, so you can give everyone feed back on the site.
Looks like you are the first to run across them.
They look like there would not be much of a balance problem with them.
rich
Jeffmcclan
Houston
We moved tire and one piece run flat from old 12 bolt wheel to new 24 bolt E wheel. Installed new seal. Don't know about multi piece run flat in picture.
