12v Ground
allenhillview
Jonesborough, TN.
Is it OK to ground any accessory at the ground junction on firewall? Installing new A/Cond. would be nice to ground there if possible, after coming through new cover on firewall.
Warthog
231
OKC, OK
Fine to do that. That block is also wired to the frame and engine.
allenhillview
Jonesborough, TN.
Thanks for the replies, I know from DH it is not ok to use 12+ that gm used at the rear battery, so I needed to ask about this. The small short wire, suppresser, between the two junctions had me concerned about feed back?
