17 inch wheels
sparkylisle
Somerville, TN
Other than having some 17 inch wheels custom made, are there any 17 inch wheels that can be mounted on a H1 that don't stick out more than the stock 16.5 beadlocks?
TOBASH
3,475
Brooklyn, NY
H1 Hummer wheels. That is if you want to spend $$$
springer1981
1,150
Maine
I looked at a lot of options, some you can find here ... https://www.steelsoldiers.com/threads/my-new-1992-m998-avenger.184818/post-2210080
I ended up going with H2 wheels. If they are stock wheels, the center needs to be machined slightly to fit the H1/HMMWV hub. The wheels stick out about 1 inch more than stock and aren't really noticeable. I can post some pictures if you want to see them.
Be sure to check out the PDF attachment at the end of the post. It has a lot of info about various wheels including width. the Ex Width column is how much it will stick out compared to stock on each side.
rjf189
99
Arlington, VA
Cepek makes rims that are stock configuration. They are NOT bead locks.
Here are the Cepek rims with 40" Milestar Patagonia tires. Note that these are sitting in front of the stock wheel/tire and thus may look a bit bigger than they are. The truck is still at RWH, but once I get it delivered I can post pictures with the wheels and tires mounted.
jkcondrey
140
Rutherfordton, NC
These are Dick Cepek 17” rims and Dick Cepek Radial FC II 37x13.5x17 tires. Not sure what the offset is but they don’t stick out bad. They do great both on and off-road. One nice thing is you can remove your half shaft bolt without taking the wheel off. Handy if you ever need to replace a half shaft on the trail.
Do you have the item # on those rims? I have done a little searching but all i find are the chromed out rims, nothing like those you have. Thanks!
jkcondrey
140
Rutherfordton, NC
Does anyone know the part number or style name for the Cepek steel wheels?? Their website does not show those particular wheels noted in the pics above.
