2-1/2 ton rockwell spindle nut locks
cranetruck
75
Meadows of Dan, Virginia
Sean, call Memphis Equipment, they have them in stock for a couple of bucks a piece. (901 774-0600 or 717-263-4194). I got some from them not long ago.
Sean Butler
It's a 4 link, the rear leaf spring pack has been flipped and is also used as the lower/outer link arms. My own invewntion/design/fabrication.
rdixiemiller said:
How did you do the rear suspension? 4 link?
Sean Butler
Thanks, appreciate the info.
jesusgatos
on the road - in CA right now
I just sheared-off the key on one of the lock-washers while re-assembling the front hubs. Anybody know if there's a part number for any similar keyed lock-washer that I might be ale to pick up at a local parts store?
