2 new projects M1009's
82ABNMP
53
Winston Salem NC
Here are a few shots of the projects underway at my shop.
1st is a M1009 that will get a 383 green paint with burgandy interior..
2nd is another M1009 that will get Tan with black interior..
I will post picks as progress moves along.
David
82ABNMP
53
Winston Salem NC
Sealer
No need to seal the top because I dont go down to the bare fiberglass, I just sand the paint smooth then prime and paint. So I did use a red oxide primer.
David
82ABNMP
53
Winston Salem NC
no gloss
C- no gloss but the Rapco 383 green does have a little more gloss than the CARC type paint. However, I have found that it holds up better to scratches because of this.
David
82ABNMP
53
Winston Salem NC
Ramesh's truck
Hi Mike, yep Ramesh's truck. I painted the bumpers and grill black today it really looks good now.
Tips on painting:
1. Watch your mixing ratio vs the air temp. Follow the mixing directions on the can. It's better a little thicker than thin.
2. Let it dry overnight BEFORE you touch it!!
3. Stir the paint very good as these cans have been sitting.
4. If you use primer WAIT 1 hr then top coat with the color.
David
davidkroberts
23
west tennessee
i found a regular paint gun was putting the paint on way too smooth and was causing a bit too much gloss. I switched to using a wagner power painter (dont laugh) to give it a more textured finish. Seems to work for military paint jobs.
I havent forgotten about you needing cucv trucks 82abnmp I just havent been in the country for long enough to be worth anything.
82ABNMP
53
Winston Salem NC
Paint
Yep, sometimes I lay it on too good (flat) and it gets a little shiny. Also, better to get back off the body and let it overspray on the paint to add texture.
David
82ABNMP
53
Winston Salem NC
Almost done!
Just need seats, and she is done. Next truck is on the way, and will be here in two weeks. Enjoy.
David
